Corona wire bug?
Is this a bug?
With all edges options it’s looks fine
Hi, any chance for us to see the file?
Which version of Corona is this?
What happens if you lower the width of the wire?
What is the full material setup here?
meshsmooth on the mesh, right? We are planning to improve this in the future, now it is known problem
yes turbosmooth, i get it it’s from invisible iterations because of isoline display.
Ok if Ondra know about it i think no need to share scene.
Not sure in the case of corona, but if you use a Mesh smooth, not a Turbosmooth, turn off isoline display to see all the edges and throw an Edit Poly modifier on top, that might help.
It does in the case of other wire frame shaders I have used.
mike_kennedy
Adding edit poly just makes the same as turning off isoline option and adding more polys what i don’t needed at wire rendering. But thanks
