Corona with Vray code
Is it just me or …, but it seems to me that the quality (there are no more those micro details) of the corona has changed?
All new renders give me that weird softness (washed out renders) in depth, materials (with same corona workflow) of vray :frowning:
I don’t think anything regarding tone mapping or post processing has been changed recently, but I am also not sure if I understand your description properly. It would be best if you could post some before/after shots for comparison. Then we could probably explain if there were some changes done regarding this, and if has anything to do with V-Ray (which I doubt).
Yup, some comparative studies conducted (academic, scientific or alike) to prove or disprove assumptions?
Nope, not just you… everyone i ever talked to (working on visuals) has or have had some kind of professional deformation :smiley:
Because, for “it seems like a feeling” know: as a live human being made of flesh, you’ll get that a lot. More & more with years working, watching, staring & checking images creating. As our vision, mind, skill, proficiency, body, … deteriorates, so do our works. This is our BIAS. :wink:
Only V-Ray code is the DMC sampler, which showed up in 1.6.3 too. Doesn’t affect materials, tone mapping etc, just noise and how fast it clears. Comparative images would definitely help!
It’s good to remember that default AA is 2px and that it’s rather soft filter to begin with. It’s kind of photographic as long as you do some tiny sharpening up, or leave it as is for 4k+ resolutions.
Hi all!
I will try to install the old version and make a test of the same scene with both versions. About Corona settings…as always, everything is set to default.
p.s. maybe I’m getting old and I see some of the things differently :)))
Just turn off AA. Get all those crispy details!
There is no V-Ray code in Corona besides the DMC sampler. The DMC sampler doesn’t really affect the aspects of the image you mentioned.
[I actually expected that all Corona issues from now on would be indiscriminately blamed on V-Ray. It took longer than I thought it would, but here we are :)]
I get a lot of V shaped artifacts lately, so I think that’s part of the conspiracy, too!
It seems to me too, from time to time…BTW I’m not doing any conspiracy! :wink:
P.s. thickness on 3d model is everywhere (floor, wall, etc…)
looks as low quality of the secondary cache (UHD) - up it or switch solver to Path could also try if changing sampler to some other helps, could also be reflection/specularity issues (but not since in other places it looks fine) - my first go would be UHD precision/proximity issues
but really, IDK…
so would you care to share/make a test scene - with similar properties/issue as you have to investigate
What are your UHD Cache settings? You could try changing preset to “animation”.
With a file in attachment, you will probably be able to detect a possible bug and also put blame on V-Ray :)))))
p.s. I think the problem is between left side reflection and right side matt material.
Cor Dev.c4d (6.36 MB)
As expected, using Path tracing instead of UHD cache helps, dialing up UHD precision from 1 to 20 helps, too (the “wise value” lies somewhere between 1 and 20, but I was far too lazy to check, where ^^).
I’d go for Path tracing anyway, but if there is something buggy, the developers must know.
Just out of curiosity - did you create this scene with an older version of Corona - your sampler is set to “Stratified” whereas for some versions DMC is the default one?
Looking for V shaped artifacts now :wink:
