Don’t know if possible, but would be nice to have ability to convert between native bitmap and CoronaBitmap via right click menu, i.e. you can right click on bitmap node in SME and choose convert to CoronaBitmap and vice versa.
the option is in the material converter, you should be able to bind it to quad menu yourself
I’m talking about right clicking on map node in slate material editor window. Converter is great and powerful, but sometimes you want to quickly convert single map and my proposed way would be perfect for that. But if that’s to much hassle to code than it’s probably not worth it.
ok. we would like to do that, but it seems it is not possible with 3dsmax…
not possible with 3ds Max ![]()
