CoronaBitmap give error "Could not load texture file..."
i try to load some hdris with coronabitmap but i got this this error "Could not load texture file: /////////.hdr
Reason: ‘#?RADIANCE’ missing in the header".
i try to load same hdri with vrayhdri in the same scene and it is working.
corona version : 1.6 Hotfix 1
Does the error occur just with a specific image? If so, could you please share the image for testing?
Are there any special (non-english) characters in the path to the image?
Isn’t this the fix to it?
Added support for .hdr maps with formally incorrect format (which are widespread and other applications support them)
https://forum.corona-renderer.com/ 1.7 Daily Builds Changelog #msg108915
an example of error-giving images;i used 2k,4k,8k & 16k this file in the scene. coronabitmap giving error but vrayhdri OK.
I selected the low-resolution one so that it’s easy to upload;
here;
cave_wall_2k.hdr
cave_wall_2k.hdr (7 MB)
fixed in last daily (already out)
the problem is that the file is not according to standard. Which is apparently common for some reason :confused:
