CoronaBumpConverter UI Bug.
As in the title:
What exactly is the bug? Is it the button in the upper right not being wide enough for the whole “CoronaBumpConverter” text?
I think the whole ui is moved to the left in the screenshot, but this does not happen to me.
I think the bug is the lack of a proper description in cecofulis post :smiley:
Do you need description, really?
As Maru wrote: “don’t you see how the whole ui is moved to the left”? ^___^
Well, it wasn’t obvious to me untill maru pointed it out, so yeah i think PROH may be right - the bug is in description too :]
It’s not a bug, it’s a tweak (both the ui displacement and descrption). :wink:
OK, as much as I like the “spot a bug” contests, please add at least a simple description to each bug report even if you think that it’s pretty obvious :smiley:
Ok, I will do! =)
cannot reproduce, this is probably caused by your local dpi/ui settings
Hm, my dpi is always at 100%, yet bump converter looks exactly like in cecofuli’s screen. Not that it bothers me though.
only the bump map? No other corona maps? Like the other recently added ones?
Only bump converter. Others looks good - i went through all of them, including materials.
weird. can you think about anything out of ordinary/default on your PC?
Don’t know. My PC for very long didn’t see fresh OS install. It tends to freeze or crash, but i don’t see UI weirdness anywhere else, apart from that small “bug”. If it’s only two of us are affected by that glitch, then i’d say forget it - i can live with that :]
