I find it enormously useful when creating any layered material or just adding some additional bump to an already finished material (think large scale noise or round edges, etc).
On a side note, if this is not going to happen, can you update the scene converter script to automatically discard the bumpmtl and just use the real mat that’s ‘nested’ into it when converting vray scenes? My files are literally full of these vraybumpmtls and I have to manually fish out the converted materials and discard the vraybumpmtls - otherwise the renders are full of red ‘unsupported’ objects.
There’s a request for an additional Bump Override slot for the Layer Mtl which would do that instead of using the bump map of each layer. Not sure if it’s on Ondra’s radar, but I know I’ve requested it in the past.
Do you mean to override the bump set up in the layers? This would instead combine or add the bump instead of replacing it.
I can see uses for both modes.
