CoronaCam in 1.7.2 - Exposure change in Cam 1 affecting IR from Cam 2
Hi all!
Scene attached, 2 CoronaCams. I think this one is a bug rather than something expected.
If you run IR while looking through CoronaCam 1, then select CoronaCam 2 in the Command Panel and enable Simple Exposure and adjust its value, the VFB takes on this exposure (even though it is not rendering through that camera). If you swap the view to Cam2 then back to Cam1, the Cam1 settings take effect again.
If you adjust CoronaCam 2 when IR is not running, then start IR, all is as expected (that is, unaffected by the changes made and using only the Cam 1 settings).
CoronaCameraSimpleExposureTest.max (568 KB)
Tested using latest Daily Build of Corona 2, plus the 1.7.2 release, happens the same in both. 3ds Max 2018.
Fixed.
