Hi guys, here i share CoronaCam Lister script. i already include this script in my daily production workflow.
sorry i dont have time to create the documentation, just try it and you’ll understand what it can do. and just ask here if you have a question.
for a technical note, i bet some people who write mxs and c# will tell me i should create an assembly or dll for this complex gui, but unfortunately my winform/wpf knowledge is still limited.. so i cant finish this step from c# way, i’ll complete this task soon.
And one more thing, there is too much tensions running in office these months which makes me got very limited time for this script development. anyway, i still always do the best i can.
CoronaCameraLister v.A5.997 -added remove selection in ExcludeList.ms (327 KB)
new CoronaCamLister v0.1.ms (327 KB)
Hello Christa ![]()
Thanks A LOT for sharing this, I’ve waited this for a long time ! I was an heavy user of VRay Cam Lister when we used VRay in prod, and a cam lister for Corona was greatly missing …
Cheers.
you’re welcome nicolasC ![]()
hi Dalton Watts, sorry its been a while i didnt use / touch this script. i assume there are many fixes needed for corona 4.
i’ll update it asap.
thanks.
edit:
i added new script in the first post above. i only fix what causing the error you’ve experienced.
currently still doesnt support any corona cam new features (1.4 above, e.g: green-magenta tint, fisheye, etc)
sorry i need to reset the version number because i’m planning to do rework and simplify some codes.
Thank you Christa! ![]()
Hello again Christa! Haven’t tested the script as soon as I thanked you in my previous post but I finally had the opportunity to do it and I only get the following dialog.
It doesn’t allow me to choose any camera even if I click ok. Suffix and prefix also won’t let me choose anything. The only thing working is if I click cancel ![]()
Thanks!
hi Dalton, sorry i have no idea what was really happening since i’m using it and runs normally here.
more clue(s) please?
Hello Christa,
Well, for me nothing happens with the script. The dialog appears but it doesn’t allow me to click “OK” or “CANCEL” regardless of what cameras are selected. Only the close window (“X”) works. How is it supposed to work? Thanks! ![]()
still got no idea but i attached a screen record.
btw i’m using max 2018.4
Hello Christa! Thank you for the screen record. That helps to clarify and I’m afraid the script isn’t working on Max 2019. Nor “OK” or “CANCEL” button work. Also, in your video it seems it isn’t possible to change tonemapping, only post processing, is that right?
Thank you for your effort Christa!
I don’t know if your script already has this feature but if I may suggest one it would be the ability to copy and paste properties between cameras, just like PhysicalCamLister (VrayCamLister) from kstudio has:
Note: Copy and paste are the small rectangles on the left. If you right click on them you can choose to copy and/or paste the respective camera settings.
There is already copy paste settings in right click menu at item name. ![]()
finally IT guys installed max 2020 (not 2019) and the script works here without any error.
can anybody please confirm that it works on 2018 but not on 2019?
Hi Christa! Reviving the topic again! I tried the script in Max 2020 and now it works ![]()
One issue though: I open corona interactive and when I change a value it doesn’t assume my input upon entering the value and only if I click in the field again. Is there a way to make it assume a value upon enter? Thanks!
