CoronaCam Overscan
CoronaCam Overscan
Script Description :
This script is made to overscan a Corona Camera.
The script allow you to overscan your render in width and height.
By modifing this parameters it will change automatically the focal lenght (or FOV) of your camera.
Key features :
The overscan is automatic, you just need be sure to select a CoronaCam before changing the width or height value and also to be sure to close the render setup windows before. (For security the scriupt will close the windows by itself).
Usage :
You need CoronaRenderer Installed !!
Select a CoronaCam
And play with the Width and Height parameter
Install :
  • Drag and Drop into your viewport
  • Open Custumize → Custumize User Interface…
  • Open Toolbar Tab- Find into “# Scripts” category
  • Drag and Drop the script into your interface
  • DONE !!
Updates :
v1.00 - Initial launch (MaxScript)
Additionnal Infos :
Script tried on 3dsmax 2018-21 and Corona 3 - 7
Contact me at jimmy.brullefert@gmail.com to do feedbacks, will be great for the community !!​​
DOWNLOAD
Thank you very much!
it’s very useful
thank you for this script !
@devs,
It would be nice to have something similar built into a corona camera.
This is great thanks! very useful.
I noticed however that if the camera is using a vertical shift which is pretty common in what we do, this will not keep the bottom and top the same.
Apprently though there is a serperate equation for that one - newShift = oldShift × (oldWidth ÷ newWidth)
I’ve tried it and works for me so leaving it here if anyone else needs to know. If I could code I would try to implement it but I can’t :alien_monster::upside_down_face:
