CoronaCameraMod Vertical and Horizontal Tilt
I would love to see basic vertical and horizontal tilt corrections in the CoronaCameraMod. These come in handy for architectural shots. Thank You.
You can correct the tilt with the default 3dsMax modifier “Camera Correction” (Modifiers/Cameras/Camera Correction)
One thing to note though is that the “camera correction” modifier will zoom out when you shift the lens, and produces basically the same results as if you simply edited the tilt of the image in Photoshop or whatever. It might not matter, but it’s good to be aware of it.
Also, if you have V-Ray, Corona supports the lens shift settings in the V-Ray Physical Camera.
It is pity Autodesk can’t do such simple stuff as proper shifting alongside poor tilt control. And I dislike to use VrayCamera (because I have to create it outside of viewport, or convert it), to use these fantastic features,
which are absolute must for architecture.
Tilt+Shift (both in vert and horizontal position) could be worthy addition to CoronaCam mod as long as it doesn’t exist in 3dsMax (might never..).
Probably never.
this is no longer needed since there is now the physical camera
