Is there any way to access the “Result Color Preview” color as RGB?
My current workaround to access HDR, HEX etc is by using separate functions to do the inverse calculations, but it would be just much cleaner if I could just run the .color through (similar to vray).
Hi James, the answer from our dev team is that it is not possible to get these values via maxscript, sorry. If this is crucial for you, you can request it through the ideas portal: https://chaoscorona.ideas.aha.io/
As I said above I currently have functions for all the color formulas, the only one I cant work out is the HDR Rendering Color Space formula. Any tips/math on how this is being calculated?
Based on the “Result Color Preview”. I want access to the “Result Color Preview” RGB values. For example in vray when changing the type to temperature or hex etc, you can just grab the color since it gets updated when those values change. In Corona the color is only related to “Solid color”, thus I need a different formula to inverse each one back to RGB values. But I cant work out what formula for “Rendering”.
Thanks maru! I’ll take another look when I get some time.
Yes this is one of the components missing for the [Corona to GLB](https://forum.corona-renderer.com/Corona to GLB ) script. Basically if you are using colors instead of textures it will put the color into the correct locations (including corona/vray color nodes).
