CoronaDistance in DB isn't working anymore with 3ds max Displace Modifier
Tested & working fine with corona-3-3dsmax-hotfix2, but not working anymore with Corona-4-3dsmax-daily-2019-04-23
Post from another user
https://forum.corona-renderer.com/ Corona Renderer 4 for 3ds Max - Daily Builds Discussion #msg148022
Test file attached
Corona Distance.max (788 KB)
It’s probably a consequence of distance map being calculated on render start only in v4 to speed up scene interactions.
A solution would be to make it optional whether a distance map is doing it the old or the new way. Best within the distance map, not as a global option. I agree that it would be needed to offer this option in v4.
If that’s the case then indeed some kind of switch would be a good compromise.
Thanks for reporting this, I’ve passed this feedback on to our dev team.
Cheers,
Rowan
(Internal ID=345578445)
You’re welcome
