I’m just looking at the CoronaImageBatch for some processing, but it is ignoring the file in the folder that the .bat file is located in.
It seems to pick up an unrelated image in the cfb history. It should be processing the sample.cxr in Y:\TEMP\j\2019\autoGlare
C:\Users\jaime>Y:\TEMP\j\2019\autoGlare\CoronaImageBatch.bat
Processing C:\Users\jaime\AppData\Local\Autodesk\3dsMax\2018 - 64bit\ENU\en-US\plugcfg\corona\history\0000-12_11_pass10.cxr
Error: There are not selected any render elements that can be saved. You need to select at least one.
If it can help:
Coronaimagebatch on i7 6800k works totally fine… no errors or missing files…
Coronaimagebatch on dual xeon 2670 v1 has still the problem…
It seems the issue is somehow related to the number of CPUs/cores/threads. There is a higher chance that it will occur on a CPU with more cores.
Also, if you go to task manager and lower affinity (e.g. set it to 1), then the error is much more frequent, even on i7’s.
