CoronaMtl - rearange maps order
I think CoronaMtl’s maps order in parameter editor window could be a little bit improved. More often used maps should be bring up in the list, less often used ones - could go down. That’d make work in parameter editor much easier, especially on monitors with less vertical resolution.
we will keep it the way it is, because the ordering follow logically similar areas
