CoronaMultiMap - Batch Texture Handler
I need to use my PNG files that have alpha map baked into them, I want to use those images Alpha channel so that I don’t need to create lots of otherwise useless alpha maps on my drive.
In Normal Circumstances, you can use:
CoronaBitmap > Channel Outputs > Mono: Image Alpha
But doing that for 30 textures seems like a chore.
Especially that I have again 15 products, with 30 variations times 12 for colours.
That would mean around 10800 clicks to handle that task, yes there are some scripts that might help but Im not sure if its that easy to get one working with 2023 and Corona 8.2
I would like to propose CoronaMultiMap > Advanced Tab or “Batch Texture Handler” so that you can add options like blur, change channels or projection modes.
I think this might help a lot of people, kind regards.
BatchMaterialEditor script might help here.
So basically you would like to change Channel Outputs > Mono to “Image Alpha” in one go for multiple Corona Bitmaps?
(Internal ID=911774027)
Pretty much that’s it, yes.
