3dsmax normal map implementation is FUBAR… so I implemented my own normal mapping:
(one is normal map, other is bump map)
This is a bombshell! Mega thanx Keymaster!
cool, good job!
Keymaster, his is great! Is CoronaNormalMpa able to convert “at fly” bumpmap or diffuse map to Normal, directly? Like VRayBump2Normal? =)
no, why? You can still use regular bump maps
Great news!
this is awesome!!!
Finally time to replace the “You shall not pass… normalmaps to the coronaconverter” message in the script ![]()
When is A5 scheduled? Implementing it for a non-public-daily release might confuse too many people.
keep it there
“Normal Bump” is still not supported, and I’ve added a warning when someone uses it. Maybe you can add a code to convert 3dsmax Normal Bump to CoronaNormalTex ;).
I am hoping to finish coding for the next alpha sometimes next week. Then I will release it after it sits bug-free for a while.
That’s the plan
I’m not really pushing to keep this crap if it’s not working. No big deal to convert it ![]()
this is unrelated to normal mapping, it is the old terminator problem. It goes away if the surface gets tesselated more.
Please get rid of the “old terminator problem”, having to tesselete the geometry more is often out of question throughout the scene.
It’s a needed feature for a renderer which wants to be called itself professional.
Please look around you, every professional renderer can handle it properly.
Are you sure?
Thank you Keymaster!!
