CoronaPattern path / color variation
I am trying to find a way to create a brick pavement using CoronaPattern, but I’m finding myself stuck. Have managed to make the pattern with some basic color and texture variation (using CoronaMix and Randomizer), but I’m struggling to find a way to create a distinct color pattern on top of that. The pavement is suppoosed to have a defined path using only colors, while the tiles themselves stay the same shape, etc. It’s kind of hard to explain, but have attached an image of what I’m thinking of.
Does anyone have a method for making something like this? I know I could use decals or a distance map, but I don’t think I’ll be able to line up the colors with the tiles that way.
I don’t think this will be possible to do using Corona Pattern. One issue that you will face with Pattern is that a single object which is at the border of a single pattern tile (a brick close to the edges or the corners of the tile) will not be actually treated as a single object, so there is no way to color it properly.
There are probably various ways to do this. My first thought was Scatter. You can scatter a single brick model (or multiple models if they should have some slight variation in shapes) and then use the Scatter Surface Color Map to define the color of each brick. See: https://support.chaos.com/hc/en-us/articles/4953359913617#h_01GF0WQAGG35RA1W48MPGGQB96
Note: this will work best when scattering the bricks on a relatively small area. If the area is very large and you end up with millions of bricks, you may run out of RAM (of course this depends on how much RAM you have).
proof of concept :smiley:
This feels like one of those cases where it’s just quicker to do it manually.
Generate the patten, add an edit poly, manually select the elements and assign mat id’s sorta thing.
Edit: Or just do it using Maru’s method which looks a lot slicker than manual haha
This got me thinking that Corona pattern needs its own surface color map. This would allow to use mapping and textures from pattern object and blend them with texture of base object. This would be ideal for situations like this.
+1 !
Thanks so much Maru! I have a lot of RAM, so I might try this and see if it works. If it’s too much I might try dj_buckley’s suggestion and convert it to geometry! Thanks both :smiley:
I actually didn’t realise Scatter can be used in grid/running grid distribution, and it follows the curvature of the surface which is perfect. Learned something else today!
I used ScatterSurfaceColor and mixed it in with the material on top, that way I can drive it using a bitmap which I can take straight from the landscape plan. Should be a fast way of doing it if my computer holds up :smiley:
Cool!
“Surface color for CPattern” makes a lot of sense, but no idea if it’s technically possible. Let’s find out. :smiley:
Logged as a feature request.
(Internal ID=1166301970)
