CoronaPhysicalMtl className return string
It’s not a bug, but anyway…
When I try to get the ClassName of the CoronaPhysicalMtl, I get a returned strange string: “\rCoronaPhysicalMtl
With line breaks :smiley: This is not a problem, strings can be filtered.
My test pseudocode (MaxSdk .Net API):
IMtlBase matBase.ClassName // MaxSDK pre 2022
IMtlBase matBase.ClassName(false) // MaxSDK 2022 and up
Maxscript returns:
classOf meditMaterials[24]
_CoronaPhysicalMtl
As I said, this is not a problem, but I have to be very careful when serializing/deserializing Json.
XML serialization result: "
CoronaPhysicalMtl"
:smiley:
this is a hack we do to list the material first in list of Corona materials. We return this from ClassName, but return normal name from InternalName. The latter should be used in maxscript. Is just “CoronaPhysicalMtl” working as expected when you try to use it? (despite max returning the “hacked” version)
I understood.
It’s probably normal practice - I also come up with some hacks for sorting (it happens) :smiley:
I think that XML and Json serialize the string differently because the UTF encodings are different. XML: UTF-8, Json: UTF-16. I am now writing a custom Json serializer to unify. I’m eliminating XML for the database almost everywhere (in some places it will remain for backward compatibility reasons) - Json is faster.
