CoronaScatter ----> ChaosScatter? Conversion
These two seem to be very similar (settings.) Is there a conversion tool/script that can save some time converting from coronascatter to a ChaosScatter?
Thanks in advance…
(regarding V-Ray 6)
You must have had (or have) an older version of Corona installed, since, currently, the Chaos Scatter entirely replaces the Corona Scatter, correct? Otherwise, I’ve notified the devs about it.
I am trying Corona version (7 Hotfix 1.)
No big issue, just wondered. I can just recreate the asset in Chaos Scatter.
Thank you very much.
Just so you know, I’ve logged the issue (internal bug-tracker id: VMAX-12551).
EDIT: @voltron7 Just spoke with the Scatter devs and the Corona Scatter is automatically converted to Chaos Scatter on scene open (you need Corona 8 installed). A message appears stating this. Could you check again?
Hello Aleksandar,
I will check again and try to install Corona 8…
Thanks again! :sunglasses:
