CoronaSkinMtl and RaySwitchMtl BUG!
Hello! CoronaSkinMtl material and CoronaRaySwitchMtl don’t work together! SkinMtl becomes black after loading into the any RaySwitchMtl slot!
I quickly tried to reproduce it, but failed, can you post a simple scene of your setup?
Any, even the most simple scene produces the same result.
I use last build - rc7.
Same happens if plug Corona material in SSS mode. Turning SSS amount down to 0 in both materials, gradually makes them to render normally in conjunction with rayswitcher.
Scene attached.
rayswitch sss.7z (91.4 KB)
Off-topic: What’s up with the shadow terminator in the pic above? Shouldn’t this look way better now or did you disable it?
I don’t know, probably SSS doesn’t play well with terminator. As soon as SSS is turned off in both CoronaMtl and CoronaSkinMtl, terminator is smooth again.
This is surface vs volume issue: https://coronarenderer.freshdesk.com/support/solutions/articles/12000012390
We have fixed this bug in v10 RC2 :smiley:
You can find it here: https://forum.corona-renderer.com/ Chaos Corona 10 for 3ds Max - Daily Builds Changelog #msg213583
Thanks,
Rowan
