CoronaSky Volume effect affect Background visibility under horizon
if I use CoronaSky as scene environment (overriding max environment) with the volume effect on the background image, put in the direct visibility override slot, appears with the part below the horizon as gray, if i uncheck the volume effect, the part below the horizon appears correctly. Is this correct? There is no way to use the volume effect on the geometry without affecting the background image?
Thanks in advance,
Alessandro
Duplicate: https://forum.corona-renderer.com/ Environment overrides + Sky volume effect = solid color stripe
also here: https://forum.corona-renderer.com/ clouds issue with volume effects on
and here: https://forum.corona-renderer.com/ BUG_sky_Volume effect_cut clouds even activate and parameter 0
