CoronaSky Volume effect + HDRI map
Hi guys!
I really like to use new Volume Effect in Corona Sky but dont know how to use it together with HDRI map.
Anyone can help?
Szymon
There is no official way (yet). However, you can try this hack:
Create a CoronaSelect map. Plug (HDRI) bitmap into slot 0. Plug CoronaSky with activated volume effect in slot 1. Select slot 0 as active slot. Then use the CoronaSelect map as environment. But it may stop to work like this in future Corona versions, so nothing to rely on.
Good Luck
OK, I found how to make it!
In Render Setup>Scene Enviroment tab there is Multiply maps options.
(Corona Mulple Environment Setup) where we can put multiple Skyes + HDRI`s.
Its possible to control each map in LightMix (LightSelect Elements needed).
Printscreens in attachement.
Szymon
