OP reported this via our support too, and it seems that currently sunlight cannot be captured by the shadowcatcher. I am still waiting for some further details, but so far I was not able to come up with any reasonable workaround.
It’s called shadowcatcher not without a reason -if the material could cast shadow, it would be called shadowcaster’N’catcher :]
One possible solution would be to detach the wall with the window and assign it with rayswitcher material with GI slot being populated with regular Corona material and other slots being left empty. You would loose ability to catch the shadows on that wall though.
that’s a long way around … It happens alot in our projects that we also want to see sunlight hitting the shadowcatching material.
We use 360 drone footage all the time, not having this feature is annoying. I remember Mental Ray was really good at these things.One of the few things I miss about it though.
The problem seems to be the Corona Sun not having the “shadowcatcher illuminator” option, which is there in standard Corona Light. This is already reported to devs.
I am also waiting for some further details from OP so I might come up with some workarounds.
Thank you so much for your time and your file. Can you please show me on the screenshots what exactly did you change in settings? I need to try it with a different project.
