CoronaVolumeMlt in Volume Global Material cause strange effect on opacity maps
We have a problem when enable CoronaVolumeMlt in Volume Global Material. The geometry opacity is not 100% clear.
If you disable the Global Material Volume, works fine.
This is known. Go to F10 > Performance > Devel/Experimental and change “enviro distance” to a much higher value. You will probably need to tweak your volume material after that.
Thank u so much Maru.
I did not know this error. For me it was a bug.
Sorry for posting it here
from programmers point of view this makes sense… from artists not so much. I increased the default enviro distance to make it less likely to happen
