Hello.
Hello i would like to know what is the correct bump map setting for vantage. it seems we cant render bump map correct even after increasing the amount to 100 ( attach images shows absolutely no bump on the floor.. value set is 100) … as we increase the amount the diffuse color changes and variation in the floor increases too. image attached
What king of map perfectly works well with bump for vantage?
thank you.
