Cosmos Browser cannot register the host application
hi,
Since today, when starting the Cosmos Browser in C4D, I get the following error message:
Cosmos Browser cannot register the host application.
I already saw in a forum post that one should check the access rights. I’ve done all of that already. Does anyone have any further ideas?
Also, since today the ‘Material’ category is missing in the Cosmos Browser as well. I think there could be a connection…
Hello Stefan,
This message shows that the host application (3ds Max, Sketchup, C4D, etc.) is not connected to the Cosmos Browser as it should be. Which host app and renderer do you use? Try restarting it and see if it will resolve.
According to this:
Can you please let us know where you read it? This is wrong and should be noted there too.
We using Cinema 4D with Corona Renderer.
I mixed something up. The answer was actually for the question about the missing material library.
Do you have a tip for me about the missing material library?
Hey Stefan,
Both issues are related. If restarting C4D does not help, can you please try (re)installing the latest Corona?
I uninstalled and reinstalled Corona and Cosmos, but I still have the same error
I’m escallating this to the Corona for C4D team.
Thank you!
Please try the trobleshooting steps listed in this document: Troubleshooting
  • Delete the DB files located at /Users/username/Library/Application Support/Chaos/Cosmos/DB
  • Open Activity Monitor and search for “cbservice”.
  • Force quit the process - it will automatically start again.
Try downloading and installing Cosmos Seperately using this link: Download | My Chaos
Also check the firewall setup to see nothing is blocking local communication between Cosmos service and Corona.
Starting from Corona 12, the Corona Material Library is now available directly in Cosmos Browser rather than as a separate category. You can read more about it here: https://support.chaos.com/hc/en-us/articles/4528349243793-How-to-use-the-Corona-Material-Library-for-C4D
You can also access Cosmos Browser by opening your web browser and typing http://localhost:30305/
If the issue persists, collect the Cosmos log files for our review following this article: Finding the Cosmos Browser Log File - Chaos Cosmos - Global Site and send that log to us by starting a ticket with us: Submit a request – Chaos Help Center​​
I had to perform the above steps in V-Ray for Maya on macOS and then restart Maya. Then the message disappeared.
