Cosmos browser crushes max
after installing newest Corona Hotfix 2
Every single time when i open Cosmos Browser from 3dsmax it crashes instantly, 2022,2023 and 2024, every single time. I reinstalled everything 2 times.
Date/Time: 2023-05-06 20:20:41 +02:00
Application: 3dsmax.exe
Error: Unknown exception - code c000000d (first/second chance not available)
Crashed Module Name: ucrtbase.dll
Exception Address: 0x00007ffde8181881
Exception Code: c000000d
When I leave Cosmos browser opened and start new 3dsmax i cant import assets either - i get this message “error importing asset: The selected importer was not found”
Exception Flags: 0
Exception Parameters:
nobody else have the same problem??
I saw that you have sent a ticket to us, and I am sorry to hear you are facing such inconvenience.
You will be contacted soon via the ticket and it is the best place to keep the troubleshooting going.
You can then share about the resolution here, so other users facing the same issue can be informed.
Hi can you please search your directories for Ucrtbase.dll, more specifically your C:\Windows\System32, C:\Program Files, C:\Program Files (x86) and see where the file is present and under which folder?
Hello, sorry for delayed reply,
I have so many instances of ucrtbase.dll :smiley: one in C:/Windows/System32 …
It looks like this is Corona issue because cosmos started from vray toolbar works perfect. (but changes renderer to vray)
Regards
@_fosafosa - if you do not have to use 3ds Max 2024, please downgrade to Corona 9 Hotfix 1 - https://data.corona-renderer.com/download/builds/3dsmax/chaos-corona-9-3dsmax-hotfix1.zip
The only downside of HF1 is that it won’t work with Max 2024.
i just exported few assets to another file and pasting them as vrayproxies…
Funny how corona nowadays need all this chaos malware to work.
4 chaos processes and 3dsmax is not even started.
