Hey,
I like the browser but some objects appear as a cube with an display tag when I make them editable.
How can I see the model again?
maybe check inside the displace tag if it is set to box and change it to another de like wireframe etc
Can you share an example? If the proxy’s vis method is set to ‘‘Full mesh’’ before making it editable, you shouldn’t have this issue.
Or you can try the ‘Duplicate to Mesh’ button. This should work regardless of the Visualization method.
Indeed it does and can confirm that ![]()
Duplicate to mesh worked very well. Thanks!!!
