Cosmos Browser - related Textures not interchangeable
Hey.
I’m using C4D and Corona on two different Machines. Problem is when using Cosmos Browser Assets, which are downloaded on both machines, the Textures are NOT found and can’t be linked automatically inside the asset browser although the Corona Cosmos related Folder is set as a default Texture Folder in preferences.
Workaround is to add the Asset again to the project and use new materials on old assets, but thats not really a great solution. Any way this could be implemented as default?
Hi there, can you tell us what version of C4D you are running? Can you also share some screenshots about the issue?
