when using Cosmos material in vantage and clicking and dragging material to object, there is a problem with an attached model with different ID material in polygons. maybe one object has many IDs and material but when drag material from cosmos to object, all surfaces of an object gives that material.
Can you give us an example scene ?
I don’t quite understand what the issue is.
Greetings,
Vladimir Nedev
Imagine you have a sofa model that is one object with multi-material (multi sub-object MTL). in vantage when dragging material from cosmos to that sofa, all parts of model give that material.
Oh, I understand now.
Yes, this is not implemented right now, you can’t apply the material to a sub-object in Vantage.
Greetings,
Vladimir Nedev
