Cosmos scale error?
As Attached image, you can see the model scale is wrong, right?
It should 1 or 10?
Hi @jackieteh ​,
Cosmos assets are originally set in centimeters, so the asset Scale will be 1 if the System Units are in centimeters. If the units are in millimeters, the Cosmos proxy asset’s Scale will be 10 in order to preserve the original size.
Best,
Viktoria
Noted with thanks. Is it possible to make it re-scale automatically follow the scene file Unit?
