Cosmos Scale
Why can’t the Cosmos objects be scaled asymmetrically in Cinema 4D as in Vantage? Could you please fix the problem.
Hi @Wohnraumdesign , changing the scale in “Model” mode scales uniformly because this is the default behavior in Cinema 4D for most objects. Scaling only a single axis is possible by using the “Object” mode when scaling.
Thank you very much!
