Cosmos test
Here is my Cosmos (and ACES) tests. Images straight from VFB (converted to sRGB in Photoshop).
Models from Cosmos library without any changes. Lighting from Cosmos HDRI.
I like Cosmos :slight_smile:
This is another one I love! This feel of presence you have! No idea how you do that lol…also what is Cosmos?
Cosmos is Chaos Group assets library for use with V-Rray:
The lighting atmosphere is great. Bravo !
How did you light your stage? Only with an HDRI?
Can you share your settings or your scene to study it?
These are amazing. Would love to know how you were able to work with ACES in Photoshop. I’ve only had luck in After Effects. Unable to figure out the workflow in Photoshop yet.
I have wide gamut monitor (NEC) which I can set to work in DCI mode (proper ICC profile is set at OS level so Photoshop “knows” about monitor).
This is my settings in VFB:
After saving 16-bit png and opening in photoshop I assign to image DCID60.icc profile which I found on internet. And I make levels adjustment layer whith this settings:
And I see image pretty the same as in VFB.
I don’t know if this is “correct” workflow :slight_smile:
