Started testing the animated cosmos trees. Initially they worked when I turned on wind, but now they don’t. 3ds max 2025, Vantage 2.5.2.
Hi Luma3d,
Are you using V-Ray 7 for Max? Because otherwise the animated trees will not work when in Live Link or from an exported .vrscene. Only trees added in Vantage will have wind animation.
Alexander
Ok… make sense. I’ll retest with trees added in Vantage to see if it works properly. Thx.
Just to be a little more clear - with V-Ray 7 animated tree asset from cosmos added in Max will be affected by Wind in Vantage even in Live link or exported to a .vrscene. If you are using official V-Ray 6.2 animated trees will not work when added in Max. They will work when added in Vantage.
Alexander
