Couple issues in Vray 7
Finally updated to 3DSMax 2026 and Vray 7 update 2.
Pretty amazing and great new features, congrats to the Chaos team! I did find some issues when using the Compact Material Editor (I still use from time to time):
-Copy/paste from map slots to other material slots does not work.
To reproduce: load a .jpg to a material diffuse slot. Right click the map slot (not when you are inside the bitmap parameters, but the main shader ui) then go to a different material and try to paste it. Nothing will happen, at least it doesn’t in my scenes.
-Select by Material does not select objects in the scene that has the material applied to, only the first object you created in the scene.
To reproduce: Create 5 boxes, go to Max’ compact material editor and select three boxes, apply the material. Then go to a different material and apply to the two remaining boxes.
Now go to Select by Material icon on any of the materials (behavior is the same on both) used in the scene, click on it. You will see that the only object selected is the first box you created.
Thanks!
-Fausto.
Just to inform, it is work fine in 3ds max 2024 with VRay 7 Update 2 Hotfix 2
Hi Jackie,
Thanks for checking!
I had a feeling that this issue could be related with 3DSMax 2026 only. Might be worth investigating, maybe something that Autodesk did that is affecting these features.
-Fausto.
Apologies, I just did more research, the Select by Material issue is on 3DSMax’ 2026 side, not Vray.
I’m downloading update 2 for Max 2026, I read it got resolved. Not sure about the copy/paste map issue that I mentioned above as well. I will put an update here as soon I run some tests.
Ok, I just installed 3DSMax 2026 update 2. That fixed both issues I mentioned in my original post.
Sorry I should have thought it was related to Max, not Vray.
Thanks!
-Fausto.
