I’m looking at the tutorial on the Spot3d site “Rendering an animation with moving objects II” but with the graphics miossing and a couple of typos, I can’t seem to get this to work.
I have a fixed camera looking at a door which opens over 50 frames: at frame 0 it is closed, at frame 50 it is open. Pretty simple stuff!!!
IRmap settings as folows:-
Medium-animation
Use Camera Path
Animation (prepass) mode
Autosave files to a folder on my hard disk
LC settings:-
Subdivs 1000
Sample size 20mm
Scale: World
Use Camera Path
Mode: single
Now, do I tell max to render frames 0 - 50 (every frame) for this to work? I assume I do. But then, isn’t the LC compnant only being calculated at frame 0 - when the door is shut? Won’t this cause errors when the door starts to open?
