Courtyard
Any comment / suggestion is welcome :smiley:
diabalance in sun ang GI
Lack of refleflections
Low quality bitmaps for textures
how should I re-balance sun and G.I? Give me some suggestions
for the reflections, there aren’t reflective materials.. except for the marble, what do you mean for “lack of reflections”?
all the maps are 2048 x 2048 jpegs
Any material reflects something even dust on the floor, use low glosy values for brick stone etc or reflective maps.
By low quality bitmaps i ment that those look like generated textures not like real stone texture for example something like this
Speaking of disbalance i ment sun burns everything away try firs to lower the value of sun intensity or try to use ibl\hdri for the enviroment
How is this scene lit? Shadows are quite strange. Maybe it’s scale issue?
The scene is lit using a daylight system with a corona sun. The sun is set at 9 Km from the pavement of the scene, its intensity is 1.5 and its size is 32. Date, time and location information have been manually choosen.
How did you arrive to this strange values and why did you chose them in first place ?
Sun is basically simulated as perfectly parallel light rays, you don’t place in space to simulate physical sun. It’s already modeled as physically correct sun.
It definitely doesn’t need to be stronger than it naturally is [1.0], and surely not the size of supernova [32]. The softest sun I ever used was maybe 4-5 ?
Hi. The Sun is a directional light, meaning that there’s no reason to put it 9km away. Only thing happening is Max screwing up because of the long distance. The physically correct size of the Sun is 1, but numbers as 2, 3 or 4 are often used to make the shadows softer. 32 is way out of range IMHO. Physical correct intensity is 1 (clear sky).
Unless you’re working with a very large city model (several km2) I would suggest a Sun distance around 50 - 100m, and for soft shadows I would set the Sun size to 4 and the intensity to 1 or lower. The Corona Sky map I would leave at default settings.
Hope it helps
Edit: not as fast as Juraj, but same message :smiley:
nitpick: not perfectly parallel. Sunlight differs from traditional directional light in Corona.
I second the nitpick :smiley:
I’ve replaced the Daylight system with a Corona Sun. I’ve set the sun intensity to 1 and the sun size to 1. I’ve added an automatic CoronaSky map to the environment slot.
By the way, this is part of an animation. As soon as it will be completed, I will post it on this forum :smiley: Give me any suggestion on how to improve lights and materials..
I was 100perc. sure this would get corrected, and I am aware most stuff is slightly more realistic but I thought for argument sake I could as well just simplify it to such point :- )
Someone could explain to me the difference between using an HDRI image as the source of light and using a Corona Sun? An HDRI image seems to give a more realistic result but is it possible to have strong shadows using this method? This is a render obtained using and HDRI map as environment (with the Corona Sun turned off).
You can prepare an empty scene with Corona sun+sky, do a panoramic render and save it as .hdr. Then use the saved image as hdr background. There should be no visual difference between using this hdr enviro and a sun+sky setup. :smiley:
change the gamma of HDRI to 0.75-0.85 to get sharper stronger shadows, and use the “sunny” hdri not the “overcast” one :wink:
