CPU AI denoise incorrect result (Corona 4 db 5042019)
Found interesting problem with CPU AI denoising.
I have one texture https://yadi.sk/i/6A6OnkMx87BiDQ
It`s the same texture resaving with PS to test with texture problem. https://yadi.sk/i/5lBJraYgnofhIg
In scene 1 Cube. With 3 lights. Cube standart UVW. Material wood from CoronaMaterialLibrary changed texture for my picute. Limited 10 pass.
Material https://yadi.sk/i/oBXND6nX2DKcqA
Second material in the bottom, its clear CoronaMtl without any changes, without any reflections. Insert only texture to the same slot.
With bouth material when CPU AI denoise active in final image i have incorrect result
https://yadi.sk/i/CRG0JVfYWRx64g
Its problem in Rest Render Element. Scene completly clear.
Denoise ON
https://yadi.sk/i/04W_24jKP5F6Zg
Denoise OFF
https://yadi.sk/i/GIG9T6xlOUKFIg
Without UVWRandomiser same problem.
Changed my texture to CoronaMultiMap
https://yadi.sk/i/Dw1gpxvP6_L7gw
ClearMaterial with CoronaColor. Color complitely same
https://yadi.sk/i/tc7HNEp7SnsXog
Another random color
https://yadi.sk/i/52sGHjkoXWY9SA
Please can you send through your scene? Instructions on how to do this are in my signiture.
Thanks,
Rowan
Send
Thanks, I have got the scene. We will look into it.
Rowan
(Internal ID=341342152)
Any ideas? Tested this bug in another PC. The problem still remains.
Noticed that she appears during envirement denoising. Tested with any envirement variations. But i think its CPU AI denoise problem with some color.
It looks like the issue is related to the denoiser, I have reported this to our development team, but unfortunately I don’t have any timescale on a fix at the moment.
I’ll do my best to keep you updated.
Thanks,
Rowan
Hi, Rowan
I noticed one interesting feature.
The darker and richer the color, the more blur. Blur leaves a little if you remove the saturation. On the test, the saturation from the extreme 255 decreases with a step of -30.
Scene
https://yadi.sk/d/nYmESrySTWFzxw
Just want to quickly chime in and thank you for those tests, the report and files you shared. This is much work done to isolate the issue. I’m highly interested in enhancing that denoiser myself, so thanks again.
Good Luck
Same also happens if you set environment to black and switch off (or delete) the lights. I already (quick-) reported this. Don’t know what’s on “02.jpg” (it’s not described, maybe just the “rest” element) but it is exactly what you get in all passes/light select elements, having no light at all in the scene.
Good Luck
Hi, Rowan.
Do you have any news?
So at the moment I don’t have a timescale on it.
We are however currently working with Intel on a fix for this, I will let you know if I have any further updates.
Thanks,
Rowan
This is fixed in the next version of the Intel denoiser, this will be included with the next daily build which is coming soon.
Thanks,
Rowan
