I work as an architect and visualizer and do my job mostly on single computer. I use commercial render farm to render big size pictures, but most of the time I need to render a lot of medium size exterior images for client’s or city’s approval. Normally 2.4k pictures are enough, and in this case render farms are not very useful because it takes longer time to clean/prepare/pack/send/receive files for them than to render set of pictures on my computer.
As many of you I have 2,3 or sometimes more project which I have to work on at the same time. In this case most useful workflow is to start render picture in first Max window for one project and work with another one in second Max window doing some modeling or other work which doesn’t need intensive CPU’s job. But even working like this I need to make some fast renders and all these times I have the same question -
Is it possible to have some kind of switcher which can give let’s say 99% of CPU capacity to the rendering which I start in second Max window, keeping 1% of CPU capacity for the first Max window just to keep rendering running without need to stop and start it again, and give whole CPU power back to the first Max window when I stop rendering in Max window number 2?
if you do the affinity solution, treat every 2 threads (0 and 1, 2 and 3, …) as single entity, since they run on the same core and assigning each to different application would randomly shift resources between the two
I didn’t know that it’s possible to change number of threads in Corona during rendering, I’ll keep it in mind! Unfortunately there is still problem to use Forest pack with Edge option from Boundary checking section (I reported about it here Corona 1.6, FP 5.3.1/2/3b grass is changing during the production rendering - Corona for 3ds Max :: Issues - Chaos Forum) which I use in all exterior scenes so I have to Lock Max UI to avoid this problem, and it makes impossible to change settings during rendering. But this solution can be used for interior scenes
“Task manager solution” is good enough, so I’ll go with this for work with exterior projects - thanks for the idea!
But actually is it possible to automate this procedure and create the “swing” system which can give all but 1 processor’s thread to the active renderer in current window, and give all but 1 threads back to the secondary window if render in current window stopped?
I’ve done some tests, and have to say that Corona solution doesn’t work in this case. Yes, I can change number of threads during rendering, but it doesn’t affect to the current rendering, Corona starts to use changed number of threads only after render stopped and started again (according to the task manager’s statistic)
Task manager solution works right away
You may do something similar with process priority only: assign your rendering max instance “low” or even “idle” priority and your working instance “normal” or one above. Now, when you render in your working instance, you should get most of the cpu power which is then given back to the “low” or “idle” max process when you are doing nothing.
Furthermore you could think about submitting your renderjobs on your local machine via Backburner as network render job (less resources needed) and check in a startup script if max is currently in network mode. It’s a one-liner and would set process priority automatically to low for BB jobs:
