Has anyone else noticed that when using lightmap in the secondary bounce that during the ir passes that the cpu usage drops by 10-15%. I have a dual 2.8 xeon 2 gig of ram and thats a lot of horsepower thats not being used. When calculating the lightmap its 100% usage and when rendering its 100% usage. Very strange.
This only happens with lightmaps!
TonyDoes this happen on any scene? Do you have hyperthreading enabled? How much RAM is used when rendering according to the Task Manager?
So far it is happening on every scene I’ve tested. I do have hyperthreading enabled but no crashes or other problems. I’ve never had any problems with hyperthreading.
The ram usage depends on the scene, of course. One scene I have used 750 meg and another 350 meg. None of the old scenes have gone above one gig of memory usage. The average is about 500 meg of ram usage.
I’ve tested a dozen or so scenes and their all having the same issue. I created a new scene with just a bunch of spheres and glossy reflections with the latest build to make sure it was not a compatability issue but still the same problem. This scene used 1.3 gig of ram with no crash but the cpu usage for ir map dropped to between 86% - 92% while calculating.
Overall, the new build is extremely stable on my system. The most stable by far of any I’ve ever used.
Its good to see this is abnormal. I did a big GI box last night (3072x2304) which took 44 minutes plus on my dual OC XEON ring (2.8->3.25). I re-rendered under finalRender (which was hardly able to keep up with 1.09.03r) and it spanked 1.45.07. It finished the scene in just over 20 minutes.
I investigated and it seemed that all of the time was absorbed by the Irradiance map calc phase. I got only two tiny buckets despite the fact that I have hyperthreading enabled, and I set my buckets for 128x128. I should have seen four of those bad boys wizzing around fast. Instead I saw two creeping around making triangles out of squares.
Of course a bucketed calc phase is different from what we saw before in 1.09 where we had a couple of scanlines move from top to bottom and bottom to top.
im having the same issue. no problems until I set the resolution to 3000x and now its stuck at 55% to 62% during imap calculation. I have dual athlon MP’s
percydaman: did you try adding “BitmapPager=0” as a line in your max.ini file? Likewise, disabling Bitmap Pager in Customization will do the same, I think.
