CPU Dropping out During Render
Hey,
I’m having an issue on larger renders (Resolution 3500x2100, quality on High) where my CPU would drop from 100% to around 4% during the “Prepass”, bringing the render to a standstill. To fix this I need to restart Revit and drop the resolution to around 2700x1545 (Quality left on High) and start again. I recently upgraded my CPU from an i5-4590 to a Ryzen Threadripper 1950X, I had the same issue with my i5. This makes me think it’s not my CPU. I also have 32gb of DDR4 RAM which I imagine should be enough for any still image?
Another weird thing is if I’m doing a render of the front of a house, I can render one image fine at Resolution 3500x2100, quality on High. If I create a new camera view (still of the front) but from a slightly different angle it wall stall at the “Prepass” stage (Sometimes during “Building light Cache” stage).
This issue isn’t restricted to one project I have done 3 similar projects as of late, one of them can be found here:
I have had the same issue across each project. My gut feel tells me it’s running out of memory but I would have thought 32GB of RAM would be heaps.
Looking forward to hearing from you.
Thanks, Nick
Hi Nick,
Can you send us the project?
Hey Ana,
Whats the best way for me to send you the model?
Thanks, Nick
I’m sending you a private message.
Hello Nick
i also recently built a 1950x with 32 gig of ram. Did you solve the crashing issue.
Im thinking of buying vray and would like to know if you found a solution.
Thanks.
John.
