Cpu fans ramping up when denoising
You want a smooth Fan curve and often the BIOS settings are beyond bad for that. Fan control in the BIOS is always limited. Although [according to this post](https://forum-en.msi.com/ index.php?topic=292789.0 ) you have in your MSI Bios more advanced settings, MSI provides a companion APP, the MSI Command Center, where you can set a proper fan curve, which you can download here. Personally I recommend SpeedFan for that, as it is the pinnacle of Fan control software both in it’s lightweight nature and detailed control. Unfortunately younger Motherboards changed the way they do FanControl and SpeedFan, which is not in active development does not detect the fan controls, but you can give it a try. Sadly you don’t get direct access to fans anymore, a regression from previous generations of Motherboards. I’m sad to have to chose between the Heavyweight Asus AI Suite and proper fan control that doesn’t suck on my workstation. All these new softwares STILL can’t do exponential fan curves, like SpeedFan does for so long… Locking fan control behind OEM Software is such a disaster…
As for why specifically Denoise makes heat and thus heavy noise…
As stated in the CPU FAQ Thread, Denoise created something of a perfect stresstest.
Also it’s heavy on the FPU, which is a nice heater element for the colder months.
