CPU-just 18%
Hello!
I got a new workstation. Intel Core i7 @2.67
When I render a scene now it just takes 18% of the cpu.
No other program is started.
When i use it with DR - the slave has 25% of cpu for max and the workstation only 13%.
Can anybody help me?
THX
look up numthreads in search on this forum, there maybe a solution for you already…
If you have a lot of vray proxies in the scene you machine may be bottlenecked on too little ram. vray loads proxies into ram when a bucket hits a proxy, lots of buckets=lots of proxy which means you can get a lot of swapping from ram into virtual memory which slows everything down
Maybe service pack 1 for 3ds max 2010 will solve your problem.
On mine computer this problem comes with Vray 15SP3a, i am using 3ds Max 2009. I dont use in the scene vrayproxy. What about solution?
Thanks for your help!
I´m using Max2009 SP1 - Vray SP3a.
I have no proxis in the scene - just Displacement.
that wouldnt have an effect on processors. just on render time
