I’m going to buy a computer So I want to ask about the details of the CPU, whether it is necessary to buy a strong one or not to focus on the graphics card.
แทงบอลสด
If you are using Corona then CPU is the primary factor that’ll speed up your rendering times because Corona is a CPU renderer. GPU is primarily used for denoising in Corona and for denoising even older GPUs can be used (CUDA is required and Maxwell generation of cards is the last we officially support so that is GTX 9xx series).
As for 3ds Max’s viewport, well, a stronger GPU will help keep the viewport more fluid if you are working on heavy scenes. In that case more VRAM will help too. Except a more powerful CPU nothing will speed up the actual rendering part though.
