So you’re saying that 1.05.30 could render that scene very quickly, and the current version you’re using is not able to render it quickly? The CPU usage is a different story, I’m only concerned about the render time. If it takes longer to get a result, then we have an issue that we need to fix.
i’m not sure if the version is the problem, just noticed that since the latest update the render takes a long time and that cpu = 20% instead of 99% in the old versions..
i never rendered this scene before so can’t say how it would work with an older version.
i thought maybe something changed in the standard settings? (like lightcache instead of qmc..)
(this render is already busy for 22 hours now, have a core i 7 with 6gb intern.. )
