Cpu
I punched in numbers around the web and I am not getting anything under $10,000 and the most expensive was $18,000, all about the same specs. BOXX was the most expensive, DELL, and then down from there.
[/QUOTE]
Wow, how did you get this high score?
I customized. The 3990X with 128 Gb of RAM. The video cards sent it over the top. Two 3090’s or one RTX 8000. Without the video cards, using my Titian RTX, I could save $5000
https://www.boxx.com/systems/worksta…83UFkwWmtVZCJ9
@glorybound On Maingear, 8300 Euros for 5950X and Dual 3090s + NVLink
This includes their insane liquid cooling for the CPU and both GPUS (nearly 2k Euros alone)
This is what Maingear could do better than Boxx or anyone else..
You could also send them your card, and ask for another titan to save around 2200 Euros
@haniel1107
yup, the normal score is around 64k or so, depending on your cooling
I get it over 80k playing with a few settings in bios, I overclocked all cores to 3.4 GHz(it is usually around 2.75 to 2.9 out of box)…
And I overclocked 4 cores on one CCX to 3.8 GHz (for single threaded performance)
I also turned off PBO, and used custom voltages.. it depends on the CPU and/or the board, I was stable at under one volte in this machine which is insane
Good memory will also help, this system has 3600 MHz at CL16 .. 128 GB
CL14 memory would even be better..
Get a 5950x, it’s single threaded performance is much better than the 3950x apparently and it’s 15% faster!
im getting computer envy…stop it :wink:
very impressive!! sounds like a lot of testing and understanding how everything works … but it was well worth your effort
Yeah, there was a lot of testing!
@Muhammed_Hamed helped me with this build( Big thanks again! ), my machine started from 43K because of a bad memory choice I picked, but after moving to the suggested memory it went up to 68K ~ iirc then to around 80K after overclocking.
I moved from dual Xeon with a benchmark of around 15k to this after 4 years so it was a big step up for me .
is this overclocking safe?
That CPU is running at under one Volt, this is actually way lower than what is used out of box.. XFR will use voltages like 1.42 and higher to go above 4 GHz on a few cores, you can check on that
I mean this OC is safer than the voltages used by default :smile: ? And the CPU runs cooler as well
So yeah it is 100% safe and covered by AMD and Asus warranties..
Most of the boards use overclocking features, specially the ones I mentioned to Bobby. They can handle more extreme settings than this.
Even if you mess up with voltages, the board turns off at 95 degrees and prior to that it warns you before you apply the settings..
The only way you can fry your CPU or board or both, is turning off all the safety features and running the CPU hot for a while
And if you ever RMA the CPU or board, there is no way for AMD or Asus to know if you did any overclocking (unless you fried the chip/CPU)
Say if something else happened, and you wanted to RMA the board.. they will not be able to know if you OCed or not.
what cooling system would you recommend? i have one sitting on a board and I can barely get to bios before it shuts down.
So I put a ‘cooler master wraith ripper’ on the 3990x and just rendered an interior scene in 20 minutes that was taking around 2 hours on a 2990wx… I’d say that’s a win
You need Noctua TR4 specific cooler then its all fine. Noctua NH-U14S TR4-SP3, Quiet Server/Workstation High-End Tower CPU Cooler | 165mm Height, High-End Low-Noise Cooling, For AMD Threadripper/Epyc TR4/sTRX4/SP3/sWRX8, 140mm Fan, Rich Accessory Kit : Amazon.ca: Electronics
interesting… I had originally put a nzxt on the 3990. the heatsink fan options are the only ones that seem to cover the entire surface area of that specific cpu. I hate computers.
NZXT is probably small on every single product right? But is standard fan efficient enough to cool down 3990X? I mean in a lot of renderings and long term.
only one way to find out
Hi Muhammed,
What cooling do you have for the 3990x ? I’m currently looking and no cooling option seems perfect. Either you have good ones, but not with a Threadripper sized plate, either other ones with bad reviews (Enermax Liqtech TR4 II for example)… Hard to find something you can rely on.
Up to now, I always had Noctua Air coolers. I’m also lurking at the ProSiphon Elite 240 which seems to be an “in between” solution but pretty optimized for the Threadripper.
Who has a 3990X and is super happy with the cooling system ?? :stuck_out_tongue:
I recently bought a 3990x with this cooler
Coolermaster LiquidML360 RGB TR4
It was the only one on the spec list the build website would use. They said all others on the list were insufficient for the cpu. Ive got a large be quiet dark base pro 900 rev 2 case which has beefy fans and lots of airflow space. So far so good!
Temperatures at full load are around 70C. Idles around 40C ish.
