Crash Dump - Render properties adjust mesh
Every time I click on RENDER>PROPERTIES to adjust the mesh, Rhino crashes. I am working with Rhino3SR4 and VRAY RC1. A collegue of mine has exactly the same problem. Any idea what do to do to fix this problem.
We already had the same problems with the previous release.
I’m not sure that is our problem. I had it a while ago when our plugin wasn’t even installed on my Rhino. If you uninstall our plugin does it stop doing that? Does it happen if you uninstall Brazil?
No brazil installed
Hi Joe,
i can try to uninstall VRAY plugin, why do you ask me also to try to uninstall Brazil?? We don’t have Brazil on our machine.
sweichert,
I’d also recommend picking up SR5 for Rhino.
Corey
Re: No brazil installed
I wasn’t sure if you have Brazil or not…Brazil is made by the same people who make the RCM plugin we distrubute with our plugin, so I wasn’t sure if you had Brazil installed or not. If not, don’t worry about it.
