Here is attached a *.vrmat file containing a simple material with a Falloff map in the Diffuse slot.
Two Bitmaps are inserted in the A and B slots of the Falloff map.
When I load the *.vrmat file in V-Ray for SketchUp, the material is created. I can open the Falloff map from the Diffuse slot. But once in the Falloff map, I see that the A and B slots are occupied, but when I click on them, the Bitmaps do not open, nothing happens.
If I save, close and reopen the model, then select the material and open the V-Ray Asset Editor, SketchUp crashes.
In the attached zip you will also find a video showing the issue.
V-Ray 3.60.03
SketchUp 2018
Windows 7
vrmat.zip (3.25 MB)
