Crash interactive rendering & bumpmap
Interactive rendering: If I activate pump channel and load a texture C4D 19 crashes. Normal rendering works fine.
Cornona B2rc1
without other plugins - same problem
C4D18 on the same PC - no problems.
When you say pump, I assume you mean bump? :wink: Can you supply us with your scene to our private uploader and some repo steps please? I tried to reproduce this but couldn’t. Thanks
yes bump. sorry. everytime in every scene. a simple cube with a material on it. all other slots are working. diffuse, translucency, reflection, opacity, displacement…
But if i load a texture in the bump map it crashes interactive rendering. The same problem if a use a c4d noise instead of a bitmap. Maybe it should reinstall c4d 19.
You could try to reinstall Corona to see if that changes anything. Having a copy of your crash bugreport and a minidump would be even better. Can you try to send us these?
https://help.c4d.corona-renderer.com/support/solutions/articles/12000033461-how-to-report-issues-
Thanks,
Thanks for your help. I sent you the bugreport, but found the problem myself:
At preferences/renderer I entered a Custom Number Of Render Threads. Interactive rendering can’t handle that.
Tested it: All channels are working except bump.
kind regards, Daniel
Hi there, So you have solved this or there is still an issue with the bump channel? If so, please try again with B2 RC2
https://drive.google.com/drive/folders/13xF3PCozC71mO-ky1hnjz6eXYqJJfd3H
Thanks,
