Crash on load in 3dsMax when using vehicles with hidden passengers
Continue having issues with Anima. I finally figured out how the workflow works, was successful syncing Anima with Max, selected my geometry, sent to Anima, placed the car path saved, Max updated cars showed up. 3d text for the passengers displayed. Hid those. Closed Max. Opened the max file and now it just crashes. I had to merge geometry into a new file, minus the Anima object’s in order for my file to work again.
Hi @Luma3d
When 3d text appears in the DCC app instead of the actors, it is useful to check what the text says as it is a hint of the underlying problem on that particular actor. Would you mind sharing a screenshot of that text?
About the crash, it would be very helpful for us if you could share that scene so we can analyze it locally, find the root cause of the issue, and provide a fix. Please, contact us throught the Chaos Help Center and send us both the Anima project and the Max scene.
